跳转到主内容
Trackpad glitch possible solution?
The trackpad seems to look and mechanically perform fine. However upon starting the computer, as soon as I touch the trackpad the cursor on the screen freezes in downpressed mode and I have to reboot the computer. Startup with a USB mouse attached and set to disable the internal trackpad works fine but I was wondering what could be wrong with the trackpad and if there might be an easy fix. The problem could have occured related to less than gentle treatment by a young child but that part is somewhat speculative. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
please give us the last three figures of your serial number to get you to the correct guide
完成的
SQ7. Thanks!
完成的
添加一条评论
1个答案
最有帮助的答案
Apple PowerBook G4 1.67 15" (Al) Specs
Identifiers: 15-Inch 1.67/1.5 - M9677LL/A - PowerBook5,6 - A1106 - 2029
The trackpad is built into the upper case: [关联产品丢失或禁用: IF154-058]
这个答案有帮助吗?
得分 1
1条评论:
Thanks, so I take it you think the trackpad, given it's explained behavour, is beyond repair, loose cables, dirt etc?
完成的
添加一条评论
添加你的答案
Johan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 531
