跳转到主内容
Support and repair information for Beats Solo3 headphones.
Doesn't turn on but flashes when charging
Hi there, I've had my beats for around 2 years now, yesterday at 7pm I was using them perfectly fine with no problems at all, and then when it came around 11pm it turned on but then shut down after a few seconds, when I put it in charge it shows 3 bars and one flashing so it's definitely not dead, and occasionally it will turn on but turn off instantly, I have tried the factory reset thing so if anyone is having the same problem or has any solutions please reply
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
RayyanS04  the symptoms you describe are pretty consistent with a bad battery. Remember that even a bad battery will tell you it is charging but will not hold a charge. Replace the battery and re-evaluate.
这个答案有帮助吗?
得分 0
添加一条评论
hi0bui9bvivbibuboihiohi097awrestdyfugihj
IDK why I’m on this site:::::::: This site helps with nothing better just to go get it fixed than waste your time on this site.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RayyanS04 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 327
