跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
Clean Washer Indicator Still on After 2 Cycles
I have run the clean washer cycle with tablets as indicated two times in a row and the indicator will not go off. Therefore, I can’t run a regular wash load. Is there a way to reset this?
Update (07/12/2021)
Hi jayeff. I have model #WFW6620HW0. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @kitcat,
What is the model number of the washer?
完成的
添加一条评论
2个答案
最有帮助的答案
Try unplugging the washer for five minutes to allow it to reset.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, but this didn't help.
完成的
添加一条评论
Hi @kitcat ,
If the reset as described by @mayer didn’t work, try running the diagnostics for the machine as shown on p.3 Activating Service Diagnostic Mode of the washer’s Tech Sheet - W11417645 - Rev B to see if there are any diagnostic error codes been shown. Look in the tech sheet to find out what they mean and their most likely cause.
I don’t know but maybe also see checks 11A through 11C on p.21-23 as cleaning the machine may also have something to do with the dispensing of the detergents.
According to the sheet, the light flashes after 30 wash cycles as a reminder to clean the machine and if not cleaned i.e. a clean wash cycle not run, then the light will turn off after 3 more wash cycles and then come on again after another 30 wash cycles have been completed.
To me one way it knows about the number of cycles is to count how many times the dispensers have been activated when dispensing detergent etc. as counting the number of times the door may have been closed and opened or the machine stopped and started may not be as accurate. This is what I think and not what I know so it may be completely wrong ;-)
这个答案有帮助吗?
得分 1
1条评论:
@jayeff - Thanks for this information. The problem here is that the clean light turns on (after “30” loads) and you can not run any regular load until you run the clean mode. And I ran it twice & it’s still not going out. I’ll see if I can find what I need in this tech sheet.
完成的
添加一条评论
添加你的答案
Cathy Matheney 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 2,925
