跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
What upgrades can I do to make faster for video editing?
Hey! I am looking for possible options to upgrade my laptop. I do a bit of video editing and am noticing it quite laggy. If I can upgrade certain components of the laptop to make it quicker that would be awesome, thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Sadly you are limited on what you can improve.
Generally RAM is the first thing I recommend if you have a 8 GB model upgrading to 16 GB. But that’s not an option here as your RAM is soldered to the logic board.
Your only option is upgrading your blade SSD leveraging it for virtual RAM (VRAM) which the OS will automatically do. And I’m sure your current drive is also quite full which doesn’t leave much space for VRAM.
Ideally, you want to leave 1/3 of your drive free for SSD’s which are smaller than 512 GB, drives larger than 512 only need 1/4 free for VRAM. If that is not an option then upgrading your SSD is in the cards.
I would jump to at least a 1 TB SSD like OWC Aura Pro X2 SSD and here is the guide to put it in MacBook Pro(15英寸,带有Retina显示屏,2013年末)SSD更换
Make sure you’ve made a good backup to an external drive using TimeMachine before starting.
The only other option is finding a used system which offers more RAM and uses a PCIe/NVMe drive which is faster than your current mSATA SSD your system has.
OWC Aura Pro X2 SSD图片
产品
OWC Aura Pro X2 SSD
$99.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gianluca Morson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 55
