跳转到主内容
The HTC U11 Life is an Android smartphone that includes models HTC U11 Life (32GB NA), HTC U11 Life (32 GB), and HTC U11 Life (64 GB). The HTC U11 Life was released in December 2017.
does the battery of a water damaged phone need to be replaced?
The phone in question is actually and htc u11 not u11 life, but for some reason that isn’t an option
So I recently replaced my battery in the phone and then killed it in a hot tub. I have another u11 at my disposal that only needs a new screen and could do with a new battery. I have the new screen and am prepared to replace it, but I’m wondering if the new battery from the water damaged phone is good to go. Is there a good way to tell? There is some light corrosion on the solder and some deposits on the wrapping, but otherwise no visible damage. When I plug the battery into the phone and plug in the phone it says it is charging and with the new screen on it appears fully functional. I just don’t want to find out that the battery can’t hold a charge or will damage the phone somehow.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Wouldn’t recommend using a water damaged battery, The actual cell of the battery could be questionable or the controller board on the battery could be bad. Not worth risking frying a logic board.
这个答案有帮助吗?
得分 3
2条评论:
Second this, I would never trust a battery that has been submerged in water. They are not designed for this and may behave unpredictably. Batteries are typically pretty cheap, I would just replace it.
完成的
Third this. Replace the battery instead of risking a thermal runaway due to shortened controller
完成的
添加一条评论
添加你的答案
River Carson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 381
