跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
How to change keyboard of MBP 2016 on my own
I need to change the keyboard. Is there any way to do it myself? I have not found the exact keyboard in any online store so far. I guess there is a reason why there are no manuals/tutorials for this procedure on this website?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, there is a reason. Most people will get Apple to do the replacement for free, using this program
https://support.apple.com/keyboard-servi...
UPDATE
Here’s a video on how to do it:
https://www.youtube.com/watch?v=6UqR9jHm...
这个答案有帮助吗?
得分 3
5条评论:
Thank you for the fast reply! The problem is I can't cause I spilled juice over it way back in 2017 and they will not replace it in this case. The only chance I had from their side was to replace the whole bottom part and this was unnecessary expensive so I decided not to do it.
完成的
Ouch! Then you'll need to replace the full uppercase assembly!
15" MacBook Pro, Top Case & KB US - Space Grey, Apple P/N 661-07954
15" MacBook Pro, Top Case & KB US - Silver, Apple P/N 661-07955
That will set you back $200 USD and you'll need a battery as well. and hopefully your touchpad is working otherwise you'll also need it too!
完成的
Hey, that sound good! 200$ is definitely worth it, the Computer itself runs as if it is new. And the Touchpad works perfectly too. So thanks for the links I'll try it.
Can I reuse the Battery that is already in the Mac Book?
完成的
@tulpenhauer - Given the age and risk of damage I would put in a fresh one MacBook Pro 15" Retina (Late 2016-2017) Battery and the guide 2016年末带 Touch Bar 的15寸 MacBook Pro 电池更换
完成的
Okay thanks for the tipps! It was really helpful
完成的
添加一条评论
添加你的答案
Josef Tulpenhauer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 396
