跳转到主内容
How do I add ram and how much ram can I add?
want to speed up my imac g3 m5521 and how well will it operate if maxxed out?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hello James Just in case your computer has the door on the bottom I am including a link to an article on upgrading early imacs. Scan down to the bottom of the article and you will see a series of pictures. Click on them one at a time and they will expand giving you a clear idea of what to do. Hope this helps you.
http://www.macworld.com/article/2496/200...
Link to a guide showing how much memory Macs can use.
http://www.everymac.com/systems/by_capab...
Maxed out it will run better but not as well as a new iMac.
这个答案有帮助吗?
得分 6
添加一条评论
Maximum RAM: 1.0 GB (2*512MB)
Type of RAM Slots : 2 - PC-100 3.3V 168-pin SDRAM
iMac G3 Model M4984 RAM Replacement
这个答案有帮助吗?
得分 1
4条评论:
This is for a M4984 -- not a M5521 and may not be accurate for his computer.
完成的
The M4984 has a max ram of 384 MB--the M5521 has a max of 1 GB.
完成的
yes I know, but I though that it was almost similar as the change in these iMacs were only hardware updates.
James follow rj link
完成的
- "almost similar", just doesn't cut it with computers
完成的
添加一条评论
Imac model M5521. Can I install a wireless connection, this has only dialup capability? Same question re DVD drive, can one be installed? Is there a source for these items?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 5,425
