跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Why are my images distorted when view them in full view?
Hello all,
I hope you can help me with my images being distorted when look at full view. Using Catalina
See the two images below... the one on the left is a clear image of a puppy and then, as soon as I click on it to expanse, the image just becomes distorted
I even tried a different viewer with same result
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Is it only this one image or others?
完成的
All images. They are stored in the iCloud. The images work fine on iPad or MacBook laptop. Just my desktop (iMac 27" EMC 2639). The iMac has been factory reset with a fresh copy of Catalina with latest updates. Soon after logged into my iCloud, this is what happened.
完成的
添加一条评论
1个答案
最有帮助的答案
@techmanuk - Down load one of the images to your local drive using file copy from finder accessing your iCloud drive saving to your systems HDD/SSD. Now open it from within Photos app. Did that work correctly?
这个答案有帮助吗?
得分 1
4条评论:
Thank you for all your suggestions... I have noticed that jpg works, but not RAW format. Is there a plugin I'm suppose to install in order to get RAW format working?
完成的
@techmanuk - RAW is a bit nebulous! RAW what? Canon, Hasselblad, Minolta, Nikon, Sony or still something else. To add to it what is the detector your camera has as that even comes into the picture.
As an example my Hasselblad 500cm CFV II digital back RAW format is not supported in Photo's.
完成的
Thank you. It all make sense now... Just looked on canon website for Canon D5 Mark II and downloaded the necessary utility/photo editor. I can see the RAW images now
完成的
@techmanuk - Thats great! Don't forget to score and accept the answer - Thanks!
完成的
添加一条评论
添加你的答案
MrRoberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 100
