跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
anyone know how to remove scratches from the shell of these?
hey everyone, i recently got two macbooks from my relative that i will use as a laptop since at the moment i dont have one, but i noticed at the bottom of each there are several large scratches going across left to right on the bottom. i guess they were well loved for years, but if i ever want to have a chance at selling these i would need to get rid of those somehow, if anyone here has an idea let me know, it would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Nobody gives a crap about the bottom - you cannot see it unless you’re servicing it, so it’s a moot point as long as the rest of the computer is in nice shape. As long as they aren’t destroyed beyond repair, don’t worry about it - realistic buyers who want a 2012 13” do understand it will have more wear and tear then a 2016-2020 machine. It’s the ones who expect a mint machine you’ll have issues with such wear, but they’re not buying older Macs like this.
In some cases, a buyer who doesn’t care as much about cosmetics may buy a blemished laptop to save a few bucks, especially if it is well equipped as-is. Unless the machine has severe damage like a dent on the edge of the Unibody (not cheap to fix, as you need to replace the LCD and chassis to properly repair it), a few additional scratches or a minor dent is not something I care about if the price and specs are right. Bigger discounts for anyone willing to take on a potentially expensive job like the LCD.
To give you an idea where this “blemish discount” comes into play, here is a realistic situation. Say I am looking at 2 machines - one machine has a Core i7, the Intel IGP and a hybrid GPU setup BUT is well loved and has more cosmetic issues (think more scratches, a small dent, etc. but no issues with the screen). The other is a nice Core i5 version of the same computer, but no IGP.
Discounted Core i7 W/ hybrid GPU setup:
  • More wear and tear and often includes small dents.
  • Better CPU at a low price due to the condition.
  • Has a GPU with hybrid graphics.
Core i5 IGP:
  • Specs are not as good, but is in better condition (easier to sell later on).
  • Lesser CPU, so may handle some heavy tasks but you may know it more.
  • No GPU - IGP only. This can be a setback in some applications.
If I had to pick between those two options and the price is similar, do you think I would care about the rougher cosmetics of the i7 laptop? NO. The CPU and graphics upgrade at a discount more then make up for any additional wear and tear! I would buy the i7 version, even if I get more looks for picking it due to the raw spec advantage.
这个答案有帮助吗?
得分 1
添加一条评论
You could replace the bottom cover if its that bad MacBook Pro 13" Unibody Lower Case and you might need replacement feet MacBook and MacBook Pro Unibody Plastic Feet
MacBook Pro 13" Unibody Lower Case图片
产品
$39.99
MacBook and MacBook Pro Unibody Plastic Feet图片
产品
这个答案有帮助吗?
得分 0
1条评论:
95% of the time, you honestly just need the feet. I've never seen a bottom cover destroyed beyond repair over damaged factory feet.
完成的
添加一条评论
添加你的答案
Matt E 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 158
