跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
118 个问题 查看全部
Laptop screen is black, can anyone help?
I dropped my laptop now the screen is black. It still powers up and sounds like the hardrive is spinning. I tried connecting it to an external monitor through the dvi and did not work. Can anyone help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Oh ouch. If connecting to an external monitor didn't work, things could either be very bad, or not so much. If no external monitor is working, it usually means that your graphics card some how got messed up, instead of you actually breaking your LCD screen.
I'm pretty sure the graphics card is soldered on for your laptop, so while you don't want to take everything out, you might try lifting up the top of your case, following this guide, and see if anything is out of place or disconnected.
这个答案有帮助吗?
得分 1
添加一条评论
A dropped computer could easily have hard drive problems--have you tried booting with your system disk and running disk repair? Nat's suggestion about looking for a disconnected cable is certainly something you would want to do. Good luck Ralph
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
todd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 3,658
