跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Battery keep maintenance message
Hi there,
I replaced my battery and used icopy to keep sn.
when I plug in 3utools
3utools show 100% ok.
But in setting iphone x keep the message maintenance and if i click show 77% same percent old baterry
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Changing the serial number to the original one will have no effect. You also need to transfer the flex assembly from the original battery as that is where the chip is that is linked to the phone. You need special equipment for this procedure like a micro spot welder and micro soldering iron.
这个答案有帮助吗?
得分 2
6条评论:
But its just happens with X?
coz another one like 8 plus / xs / 7 I use icopy and works well.
完成的
@diogotm From the X up. I don’t see how it would have worked on the XS. There are videos on YouTube showing the procedure.
完成的
look the videos bellow
the both dont need replace the microchip
https://www.youtube.com/watch?v=LlOFNepk...
https://www.youtube.com/watch?v=UJCnuC5f...
完成的
@diogotm Well there’s your problem. They just replaced the battery without copying the serial number over.
完成的
That’s make sense, if you copy serial to show 100% in 3utool you can’t change the percent health in iPhone settings
But if you DONT use icopy you have 100% health in iPhone setting. BUT if you plug iPhone in 3utools they show the red message “the battery my be replacement”
OMG apple apple
If I like the both 3utools 100% and iPhone setting health 100%
I need to swap a microchip, right?
Thank you very much your patience and your answers
完成的
显示更多的1条评论
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Diogo Thomaz de Melo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 200
