跳转到主内容
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
35 个问题 查看全部
White screen when I tried to run pokemon emerald on a Ti Nspire CX II
When I tried to run pokemon emerald on a Ti Nspire CX II, it just gives me a white screen and I don’t know the reason behind it. I reset my calculator multiple times. I have endless installed. It worked one thing and after that, it never worked and whenever I tried to run it, it just gives me a white screen. Can someone show me how to fix it or teach me? That would be appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To be clear, your calculator is functioning normally as a calculator, it just won't run Pokémon?
If so, try moving some files from your RAM to your Archive. Unfortunately I don't know much about the Nspire calculators, so you'll be better off posting a question like this over on TI-Planet where they specialize in all things Nspire. Although the site is in French, the members will be happy to help you in English if you need. Here's the best place to post your question: https://tiplanet.org/forum/viewforum.php...
If you can't get the calculator working normally, try following this guide: https://tiplanet.org/forum/viewtopic.php...
这个答案有帮助吗?
得分 0
1条评论:
I was able to run pokemon emerald for a bit. After a while, when I tried to run pokemon emerald it just gave me a white screen. I am also able to run pokemon silver.
完成的
添加一条评论
添加你的答案
DAVID ZHENG 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 306
