跳转到主内容
The Samsung Galaxy A71 is an Android smartphone manufactured by Samsung Electronics as part of the Galaxy A series. It was released in January 2020. Versions: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Russia).
84 个问题 查看全部
I can not turn off my phone
My phone fell in water and when I took it out and turned it off it turned on by itself. And now the power button does not work. I tried to turn it off in settings without the button but the same thing happens. I really do not know what to do because I can not find someone on internet with the same problem. Also my camera is blurry.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Your phone is water resistant, not waterproof.
Check the colour of the LDI (liquid damage indicator) in the phone
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a teardown video for the phone which may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dunja Jankovic 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 90
