跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
New 1 TB SSD installing
Hi..
My MacBook Pro late 2011 was acting very strange for a couple of days. When startup, it showed a grey screen with thin stripes, sometimes bluescreen with white thin stripes. It would shut down and start up again, but the satus bar only got half the way and then it was shutting down. So I thought it was the 500 GB SSD drive that was faulty, but the hardware test (cmd + D) didn’t show any fail! Suddenly today it was starting up perfectly!!!! I already got a new 1 TB SSD disc to install, so the question is….what could be wrong with the Mac and how do I use my timemachine backup (I have just performed a new backup) to the new 1 TB SSD disc that I planed to install..after all now I have it ;-)
Thanks everyone for reply…..hope the MacBook Pro still survives some years.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If Dan’s answer fails, it may be a known issue with the GPU on the 15” 2011 MBP. This can sometimes be resolved using a program that shuts down the discreet graphics on the GPU so the integrated is used. It’s call Gfxcard status, It can be downloaded here:
https://gfx.io
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Replace the HD SATA cable! Your Hard Drive Cable Is A Ticking Time Bomb. Use the better cable from the 2012 series MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable and here’s the guide MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement
Replace a damaged cable connecting the hard drive to the logic board in your laptop.图片
产品
$19.99
这个答案有帮助吗?
得分 1
2条评论:
So the startup failure is due to this cable..??!! I will try this fix and hope for the best ;-) A new Mac Book Air is horrible expensive here in Denmark, even the base model. Thanks again....
完成的
@tdnm - A very common issue! Don't crease the cable as that damages it as well.
完成的
添加一条评论
添加你的答案
Erik Schmidt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 104
