跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Wont charge and heptic feedback of home button does not work
After replacing the screen assembly and lightning connector assembly the phone wont charge and home button feedback does not work.
Otherwise phone seems to work OK.
I checked all the main connections,but the problem remains.
Any suggestions?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It sounds to me that the replacement part you have is faulty. Have you also checked to see if the speaker is working? If not then its definitely defective as all those components run off the charge flex.
这个答案有帮助吗?
得分 2
3条评论:
Thank you for your reply.
Speaker is working fine.
All the replacement parts were ordered thru ifixit.
Do they have any tech support I can contact with my problem?
完成的
I' ve linked the support page for you; https://help.ifixit.com/collection/130-c...
完成的
Thank you:I have contacted them and provided all the photos they asked.
They are sending the new components needed.
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Butrus 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 33
