跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
MacBook cursor not moving
I have a MacBook Pro mid-2012 running OS 10.14.6. I'm unable to move the cursor using the trackpad.
More details:
-I'm able to click everything perfectly fine with the trackpad. -It seems like the cursor slightly moves when I press quite hard on the left-hand side of the trackpad. -I don't know if this related but my MacBook shows "service battery", the cycle count is 651. -I've tried NVRAM, PRAM AND SMC reset.
Any help is highly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your touch surface sensor has failed, time to replace the part MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad and here’s the guide MacBook Pro 13" Unibody Mid 2012 Trackpad Replacement
Replace a scratched or malfunctioning trackpad in your Mid 2009 to Mid 2012 13” Unibody MacBook Pro model A1278 laptop. Part #922-9063, 922-9525, 922-9773.图片
产品
$54.99
这个答案有帮助吗?
得分 0
8条评论:
Hi Dan, thank you so much for your reply. I've been reading up on this on various outlets and some people are alluding to this being caused by a swelling battery? What are your thoughts on this?
完成的
@karx25 - If the click was having an issue then I would have agreed.
For the sake of argument, let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片 that way we can see the batteries health.
完成的
@danj Hi Dan, thanks once again. I've attached a screenshot of the coconut battery app. Just an update: Oddly enough, I was able to move the cursor perfectly fine for about 15 minutes last evening. But, once again, it stopped moving after the next boot.
完成的
@karx25 - Clearly your battery needs to be replaced for a year old battery its not healthy!
I would see if its covered under warranty as its just coming to a year old (2020-05-07)
完成的
@danj so would this confirm the battery is the reason for the cursor issue?
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Karthik Sathian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 91
