跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
Problems after changing iMac Hard Drive
I changed the internal hard drive on my 2008 iMac and after replacing I
attempted to install Mac os lion on it and it is not allowing me in any way. I
try restarting while holding the c key to boot from CD or restarting while
holding the option key and when I do this I can scroll with the mouse but it is
an empty gray screen with nothing to boot up from. If I turn it on and let it go
it goes to a black screen saying no bootable device insert boot disk and press
any key but I am trying to boot from the CD .
All help would be appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You need to use your original system installation disk to format the hard drive using Disk Utilities. You may then need to do a install of 10.6 and update to 10.6.8 and then install the Lion.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
manaury 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,377
