跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
No backlight
Hello.
After repairing a broken glass from an iPod touch 4, the backlight seems to disappear.
Now have no backlight at all.
Any suggestions? What could had been wrong?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
they might have done some mistakes in the wiring while removing the cracked screen. Or it might be something else.
完成的
添加一条评论
2个答案
已选择的解决方案
Try to check your LCD connection that no pins are bent. Reseat the connector. That connector is very fragile and always be gentle when seating the connector as you can bend pins. Take a look at why I once lost backlight on a 4g Touch: https://www.dropbox.com/gallery/943721/1...
If it looks ok I would try to do a software reset. A lot of times you loose backlight or white screen if you reassemble and accidently have switched it on.
这个答案有帮助吗?
得分 3
添加一条评论
try unplug the battery and reset it first
if that didnt fix it
You can now get both backlight Coil and IC for less than 5$ each here
Ipod touch backlight solution
这个答案有帮助吗?
得分 0
2条评论:
Right now it appears that you can not add anything to any repair or fix other then parts. Please use your profile to place your URL in there.
完成的
you need to change the coil, when the backlight blinks and finally dies thats usually the coil going bad due to moisture.
fyi repair video update
okay this is a soldering repair video on iphone 4S backlight coil
the whole soldering process is the same for ipod 4th
http://www.youtube.com/watch?v=Bsk6rg0KX...
完成的
添加一条评论
添加你的答案
helderbernardo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 6,103
