跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
How to replace buzzer?
hello, how to replace buzzer in 3gs? can i must use the soldering iron? any instruction please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
iPhone 3GS Vibrator Replacement
There's the guide from here :) no soldering needed, just need to take the screen assembly off, un-screw the logic board / disconnect cables from it and remove that, then it's just a couple of screws to remove the current vibrator.
If it doesn't seem damaged, you can try and bend the pins up towards the logic board again, it may have just come out of contact with the bottom of the board.
Hope it helps.
这个答案有帮助吗?
得分 2
2条评论:
sometimes it's the mute switch causing problem..it's only a tiny switch. Does iphone recognise that mute/vibrate is switching on but you have no vibrate, or does nothing happen when you flip the switch?
完成的
Good point, check what pollytintop advises as well! :)
完成的
添加一条评论
添加你的答案
wysoki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 786
