跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
93 个问题 查看全部
Is the EMC 2833 compatible with the EMC 2889 or 2805 kits?
I seem to have a failing hard drive on my 21.5” iMac with EMC 2833. It has a 2.8Ghz processor.
Is this of a series with the 2803 or the 2889? Or is it neither?
Can one of these work with my machine?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Please recheck that EMC number from the bottom of your stand.
完成的
I can send a picture. I took a picture to be certain.
I see "EMC No: 2833" under the bar code looking thing and alongside the serial number.
I also see "Model Number: A1418" .
I can open the "about this mac" window if that helps.
完成的
It's a bit confusing as Apple produced two versions the original Retina EMC 2889 (iMac16,1) and the 4K Retina EMC 2833 (iMac16,2) both are part of the 21.5" A1418 series.
I've corrected your model info (the icon on the right)
完成的
添加一条评论
1个答案
最有帮助的答案
If you have a HDD model then you can just replace the 2.5” HDD with either another HDD or upgrade it to a 2.5” SSD
Here’s the guide to open your system to get to the drive: iMac Intel 21.5" Retina 4K Display Hard Drive Replacement and here’s one option iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit as most people just upgrade to the SSD. You’ll need the tools and adhesive strips to open the system that comes in the kit.
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit图片
产品
$89.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Beth Levy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 75
