跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Internal SSD not recognized by any operating system
Hi! Recently I’ve recovered my MacBook Pro, but it won’t recognize the internal SSD. I’ve tried with another OS (Ubuntu) to see if it was an OS problem, nothing.
I opened my Macbook and I touched the SSD and it was hot. I can’t understand where’s the problem.
And also, the fan is always at the maximum RPM.
Please help, it’s a very good laptop and I want to rescue it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like the SSD is gone. But before you buy a new one lets test the system by using another Mac to create a bootable USB thumb drive.
You’ll need to setup High Sierra accessing the OS installer here How to get old versions of macOS and following this guide How to create a bootable macOS High Sierra installer drive Make sure you’ve first formatted the thumb drive to GUID and a journaled file system.
Now with this at hand pull the blade SSD following this guide: MacBook Pro 13 英寸配备 Retina 显示屏2015年早期版SSD更换 following the first six steps before pulling the SSD. Then with the thumb drive plugged in, reconnecting the battery the system should spontaneously restart and the thumb drive should boot up as we don’t have an internal drive to prep you’ve proved the system is OK other than the internal drive.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your answer. I've notice that if I plug out the SSD, the fan stops rotate crazy, I think the problem is really the SSD. I bought a new SSD and I'll follow the tutorial, thank you again for support.
完成的
添加一条评论
添加你的答案
Birbone 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 38
