跳转到主内容
加入维修社区 - 创建账户
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
I can't seem to get a new battery to charge in an iPhone XR.
Have installed two different new batteries in an Iphone XR. Plug the charger back in and it just sits in a boot loop. I see various current draw from the volt/amp meter that I have the USB plugged into so I know it’s trying something. But it’s just stuck in a boot loop. I left the new batteries to charge for multiple hours and nothing. If I plug the original battery in everything is fine. Any feedback would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
where did you get the batteries from?
完成的
@hootonberg
One came from Mobilesentrix and the other was from MobileDefenders.
完成的
@itsd_btech ok good so we can eliminate those an a potential issue. Maybe try a DFU mode restore?
完成的
I tried that on both, nothing. I've have another battery I ordered from here. I'll see if that's the fix.
完成的
添加一条评论
2个答案
最有帮助的答案
If it works fine with the original battery but doesn't work with the aftermarket ones I would have to say the batteries you bought were probably not the best quality. I buy my batteries from fixez.com and I haven't had any problems with them. They even have the original to chip from texas instruments. It's what tells the battery health and percent of charge. It can have issues if you have a cheap battery.
这个答案有帮助吗?
得分 1
2条评论:
Allan, thanks for the feedback. I'm tearing this phone down today (again) to install a battery I purchased from fixit. Also to see why the taptic engine isn't responding as well. Wish me luck and I'll keep y'all posted.
完成的
Battery works just fine.Problem now is my taptic engine and lower speaker don’t work. I’ve tried different taptic engines and different speakers and went all the way through to replace the charge port cable assembly. Interchanged the taptic and speaker on the new charge port assembly and nothing. Haptics are still enabled in the settings and all that jazz. Anyone have any ideas?
完成的
添加一条评论
Well everyone, the new battery I ordered from ifixit worked just fine. So that fixed that problem.
Cheers everyone for your help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
I.T. Service Desk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 122
