跳转到主内容
加入维修社区 - 创建账户
任天堂2DS是一台掌上游戏设备,作为任天堂3DS的入门版本而开发,在硬件上与3DS完全相同,但没有裸眼3D功能
2DS won't charge and shows no charging light
Hello! I bought a 10€ 2DS just for fun but it doesn't charge the battery.
What I've checked so far:
  • Battery (ok. Charged externally, holds it's charge and powers the system just fine)
  • Charger (5V ok)
  • Charging port and fuses
  • With the 2DS opened up and the charger attached it doesn't start. The yellow charging indicator doesn't light up at all. I have the 5V off the charger on fuses F1 and F2, before and behind the voltage filter and even on the battery pins.
I think the charging IC is shot. Or are there other things to check? Maybe it's an easy fix.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hello,
Go to this website if you charging port is not working but the cable is fine: Nintendo 2DS Motherboard Replacement
if the port is fine but the cable is not you may just have to buy a new cable
这个答案有帮助吗?
得分 0
添加一条评论
The port and the charging cable are okay since I checked the voltages on both of them.
这个答案有帮助吗?
得分 0
1条评论:
Did you get this fixed? I'm having the same issue now.
完成的
添加一条评论
Did you fix this after?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 635
