跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
Dualsense not lighting up without any reason
Hi guys,
my dual sense not working when i press the PlayStation button it’s not lighting up and when i put it in the charging station it’s lighting orange indicated like it’s full charged but not lighting at all when i press the play station button.
I have recorded a video for the issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
I have the same issue
完成的
Bro ! What happens when you plug it to usb ? I think I have the same problem . It won’t light up not even connected, but I don’t have the dock to try it.
完成的
添加一条评论
1个答案
The image is just for illustrative purposes and is not necessarily precisely how your version will look.
First try plugging it in via usb to a pc. Use a gamepad tester site. See if the face buttons and digipad are also not working. This can matter and give us a clue.
See the area circled in red labelled "Connector"? This part is pressed against the board using a rubbery sponge block. The board side of the connection is conductive paint.
Things that can go wrong.
It can just be as simple as debris has worked it's way in between the flex circuit board and the pcb. If so clean both the flex cable side and the pcb side of the connection with isopropyl alcohol (higher % IPA is best).
Another possibility is the rubbery sponge has lost it's shape and isn't pushing the flex circuit firmly enough against the pcb. In which case replace the sponge, or try bolstering it with a small bit of electricians tape or the like to add a tiny bit of thickness to the sponge.
If the flex circuit film connector contacts are worn away or damaged, replace the whole circuit film.
If the conductive paint traces on the pcb are damaged or worn away you could try adding some new layers of conductive paint.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mohamed Alfarsi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 31
总计 1,103
