跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
What is wrong with my wifi?
I am running on IOS5 and my wifi was not working so i got a new wifi part and it is still not working. I have restored and jailbreaked many times and it can never detect a network even when my other devices can.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
the Bluetooth works i was able to connect to my blackberry
完成的
i am unable to detect networks when i open wifi, i purchased a new attena and there is no difference
完成的
添加一条评论
2个答案
最有帮助的答案
Can you please look up the following:
- Is your wifi greyed out (i.e. not able to open the wifi menu at all) or is it just unable to find networks?
- Lookup under Settings / General / Info the WIFI Address (MAC ADDRESS)
If your wifi is greyed out and/or there is no WIFI Address then there is probably not a problem with your antenna but there is a problem with the WIFI chip.
If your wifi is not greyed out try standing as close as possible to the router to see if you get wifi signal then. If you get it then there could be a problem with your antenna OR the circuit on the logic board going from the WIFI chip to the antenna.
Please let me know the results so I can help you further.
这个答案有帮助吗?
得分 1
3条评论:
完成的
Ok then you probably have a problem on the logic board. If you are certain that the antenna is correct and the connector is in place you might consider reflowing the WIFI chip and the coil next to it.
In the following YouTube video it is explained how to reflow it: http://www.youtube.com/watch?v=7E34y9l49...
完成的
ok maybe it is the attanna, its now fluctuating in detecting the network and not detecting
完成的
添加一条评论
My 3GS IOS5 has the WiFi grayed out and No WiFi. Have reset Network Setting, no wifi address. What now? This happened when did 5.1.1 update. Had to restore phone in order to complete update and now no WiFi
这个答案有帮助吗?
得分 0
1条评论:
there were problems with the ios 5.x update and greyed wifi which were meant to have been fixed see if you have any earlier ios restores in your itunes library to go back to. You may need to do a jailbreak..https://discussions.apple.com/thread/395...
完成的
添加一条评论
添加你的答案
phil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 6,167
