跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
iPad Home Button not working after Digitizer Replacement
I replaced the digitizer specifically because I accidentally broke the home button connector ribbon. I have to use the one I have (the new one I mean) or buy another. When I connect the digitizer and LCD panel, the home button does not work. I have not fully assembled the iPad yet, as I wanted to check if it worked. Do I have to fully assemble to get the button to work? and if not then can anyone see my problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
That looks like an iPad Air home button, which carries a different protocol and is not compatible with iPad 5.
Either that or the home button is faulty.
这个答案有帮助吗?
得分 1
2条评论:
That’s actually a really helpful input, when I bought it it was labeled as a digitizer for iPad 5 or iPad Air. So does this mean that it just really isn’t the right home button?
完成的
@Nathan Mayo That explains it, you got the wrong home button (iPad Air)
完成的
添加一条评论
添加你的答案
Nathan Mayo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 64
