跳转到主内容
加入维修社区 - 创建账户
iMac Pro,Apple 迄今为止性能最强的 iMac 。可选配置包括3.2 GHz 8核,3.0 GHz 10核,2.5 GHz 14核,2.3 GHz 18核 Xeon W 处理器。EMC 3144 / A1862 (ID iMacPro1,1)
Is it possible to diagnose a bad power supply in an iMac Pro?
Hey guys. I have a late 2017 iMac Pro that recently just completely stopped working without warning. Worked fine one night, then the next morning it wouldn’t turn on. I tried different power outlets, I purchased a new power cord, and nothing changed. Then I took it apart. There are four points where the power supply makes contact with the logic board and I noticed one of those connections wasn’t touching. I remedied that, cleared out any dust, put everything back together, but still nothing. Can anyone tell me if/how I can test my PSU to see if it’s bad, or what else I might be able to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
FYI: I had the same exact thing happen to my iMac Pro on the 8th of May. It just stopped working. No power. No hum. Nadda. Ziltch.
Took it in to the Apple Store and they fixed it with a “hard software reset” which, it seems, included the EFI firmware and OS. Oddly, the cost was $0. Sounded odd to me.
A firmware update gone bad?
完成的
I would recommend you disable auto update. Apple has been sloppy with the updates and upgrades and killing services you maybe dependent on.
As an example Catania killed 32bit apps and add-on's (as example some photoshop plug-ins)
Letting your system take care of things automatically does have its appeal. But, is it wise??
∙ The amount of work it takes to back-wind an update it a killer because it killed your Bread & Butter tools!
∙ When the update messes up the EFI or fails to finish bricking your system is likewise a killer!
∙ Then the worse is when it beaks a part so you now need to replace it as in the case of the 2014/15 I/O board as the HDMI chips firmware was altered in the update process and you can't undo it!
There was a point Apple had a good working update process its now gone! Over the last 10 years feature kill has been going on! What made OS-X a great OS is now gone in the macOS versions! I can understand some of the reasons this happened but I think its gone too far!
The Install/update process timeline is a joke! Its not even close! 3hrs is listed yet it only takes 45mins!
Then in years past you had one reboot. Now you can have up to four! And the screen is blank on most of them! OK, I know I shouldn't reboot or turn the system off but is it done or not? Which do a number on you not knowing.
Apple > You need to fix things!
∙ Security updates - Clear notification <<Urgent Alert>>
∙ Maintenance/Fixes (Minor) - Clear notification, listing of affected OS subsystem, have the ability to backwind
∙ OS Update (Major) - Clear notification, have the ability to backwind
∙ Apple Core Apps - Clear notification, listing of the apps being effected, have the ability to backwind
完成的
I'm having the same issue after a screen replacement but the power supply is making a very faint beeping noise and I get no voltage across the screws. I'm ordering a replacement power supple just to test that the motherboards not fried. The weird thing after the screen replacement the machine powered on showed the Apple logo then shut off and will not power back on even with old screen. If I remove the plug coming from the PSU to the logic board the beeping stops but still no voltage. I think the plug with a few wires is some kind of sense wire.
完成的
添加一条评论
2个答案
最有帮助的答案
Well, there are a few things you should be able to check to see if the logic board is getting power. Using a DVM are you able measure the voltages across the two screws on each side of the power supply?
Is the logic board onboard diagnostic LED’s lit at all?
这个答案有帮助吗?
得分 1
5条评论:
I measured 12v on both sets of screws when plugged in and there are no LEDs lit on the logic board.
完成的
@dbarker16 - This sounds like a logic board failure ;-{
Time to put the system back together and visit an Apple Store. Make sure you use the correct tapes and haven't left any signs you've been inside.
完成的
Crap :( Thank you for your help
完成的
What are the diagnostic LEDs showing with the machine plugged in. What do they do when you try to power up?
完成的
@mayer - There doesn't appear to be any lit onboard diagnostic LED's. Yet the power supply is reporting power at the two feed points.
完成的
添加一条评论
Attempting to service this same iMAC pro with a 'no power' case. A few corrections.
Apple (Foxconn) DOES have a bank of DEBUG LEDs onboard. By default, they will not light up unless you press the tiny pushbutton that is just below the same row of LEDs.
If the first left LED enables with the pushbutton, then the power supply which is feeding the 12v rail is ON. Be very cautious of the high voltage near the exposed power supply. This unit is a shock hazard.
After some probing, we are facing that PP1V8_S5 is @ 0 volts. All rails from this and lower are at 0 volts. On a macbook, usually a DFU corrects the PP1V8_S5 rail. For us, even with numerous attempts using Configurator 2 and different USB cable, facing Error Code 9 on the DFU revive process. Currently stuck on this repair.
From our understanding, PP1V8_S5 is created by a leg on the PMIC @ U7800. Do not feel like replacing this complex PMIC nor know of reliable of sources for this part. The higher current BUCK3_LX0 leg IS WORKING. No short on the missing rail so may attempt a bypass.
这个答案有帮助吗?
得分 0
7条评论:
@mon2 - My bad when I originally wrote my answer, I should have noted the switch which as you noted needs to be pressed.
Whats the background history here? It does sound like the rail has a problem. Did you try using a IR camera to see if there was a hot spot on the board (short) Haven't seen your issue, but I have seen a few Tantalum capacitors fail which could cause a short.
完成的
Good point. Will set up the thermal camera and inspect. Will update this thread. The logic board looks clean and just died one day according to the owner. We have not yet taken apart the logic board to inspect the other half of the board. Rossmann forum mentioned to attempt a firmware flash but do not feel comfortable on this unit. Will check the thermals first. So far, no shorted caps onboard. Appreciate your feedback. Thanks.
完成的
Now this is interesting..following a thread here where we diagnosed a macbook which was missing the same power rail. The resolution was the power supply was not able to properly power the logic board.
https://www.badcaps.net/forum/troublesho...
See post # 7 of the referenced thread.
Could the power supply the same fault? Will study further.
完成的
@mon2 - Are you reading 12Volts on the transfer rails?
完成的
Hi. Yes, 12v as well as 3v3 are present. In the above badcaps link I have posted the power sequence chart and this power up stops @ PP1v8_S5.
Attempted a DFU which times out with Error 9. Used assorted qualified USB cables but still stuck here. The USB load switch is NOT enabled on this motherboard. The enable for the USB load switch is from the PCH but the CPU / PCH do not yet have power. Can enter RECOVERY or DFU mode but always times out.
Read on Rossmann forum that the fault could be the CD3217 PD controller. We may consider to replace this device if required. Somewhat tempted to bridge the other 1v8 (3A) created by BUCK3 onto this 1A 1v8_S5. This PP1v8_S5 is not shorted. Suspecting corrupt firmware.
BTW: If the fan socket is lifted, the fans spin into hyper speed mode so there is some life here. The CPU does not appear to be shorted.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Daniel Barker 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 91
总计 2,800
