跳转到主内容
Guides and support for devices that play video from DVDs.
286 个问题 查看全部
Drive is not spinning some discs correctly and making loud noise
Suddenly, my DVD drive cannot read certain discs. When it tries, it makes a loud whining noise when spinning and gets read errors. Other discs read perfectly fine!
I opened the drive to investigate. The problem seems pretty simple: the way this drive motor works, like many CD/DVD drives, is the there is a soft o-ring like material on the surface motor head. See the black outer ring in this photo:
That is what makes actual contact with the inner disc ring, and when the disc is seated it is under pressure and forces the disc to spin with the motor. On my drive’s motor head, however, this material has worn away and the failing discs are probably just slightly thinner ones are slipping against the motor instead of spinning (I do notice some signs of that on the discs themselves looking at the inner ring).
So knowing the cause, my question here is how do I fix this? I don’t know what this soft ring material is called, or where to get a proper replacement to stick on the drive head. This looks like a very cheap, inexpensive fix (like most electronic failures), and it would be overkill to change the motor or even whole drive over something this simple.
Thoughts on what you would use to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Could find something like this, cut to size and melt together. https://www.amazon.com/40-135MM-Cassette...
这个答案有帮助吗?
得分 0
添加一条评论
You are having problems with the spindle motor disc holder.
You will have to change the complete spindle motor assembly - Mabuchi RF-300FA-12350 DC Motor, as the disc holder is integral with the motor.
It's available in eBay.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Parker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 31
总计 1,111
