跳转到主内容
Sixth generation of Apple’s wireless base station, released June 2013. The tower provides dual-band support wireless access and is Apple’s first router with 802.11ac technology.
28 个问题 查看全部
AE orange light blinking, no wifi or cable connection
hey experts … I have a riddle here … I have Airport Extreme blinking orange (amber) with no other light (lan sockets), no wifi and no connection via cable. Tried to reset it - no luck so far, tried different power boards - same behavior - so I think the power, fan is OK, but why orange is still blinking and no other sign of life is there … even fan was cleaned but does not spin … tried new fan as well but not spinning as well … any advice what I could try ? I know it’s old but I like fixing things … thanks in advance !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The blinking LED is telling you its trying to update its firmware. Using the uplink Ethernet port connect it to your Internet router so it can finish.
You should also plug in your Mac system into the same hub as your AirPort and use the AirPort app to check on your Airport unit.
这个答案有帮助吗?
得分 0
5条评论:
hi mate, maybe you did nit read correctly what I wrote or I did not explain it very good, but none of the LAN ports or WAN show sign of life ... I did what u recommended as it was almost first thing what came to my mind, but no luck, no show in Airport app - with cable in or on same wifi as my uplink router ...
完成的
when I connected it to the uplink, wan port went live for 2 secs - then down. When I am starting the AE on, solid green is on for a second, then solid orange for few secs and blinking orange ...
完成的
At this point your AirPort logic board needs deeper inspection and testing. Clearly something is wrong at the circuit level.
完成的
would be great to know where to start ... any idea how could I reset it on the board in case the button is not working ...
完成的
Simply short across the two wires that run to the switch. I had a dead unit and to make it easier I took off the switch soldered two wires to create extension lines and then I used a different push button switch.
完成的
添加一条评论
添加你的答案
phoenixx 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 26
总计 693
