跳转到主内容
The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
82 个问题 查看全部
water dripping from detergent tray
I noticed after the wash cycle ends that the clothes were kind of still wet…i put on drain and spin…fine…but then what i noticed is that there is water dripping onto the clothes from where the detergent trays are located…I removed the trays and it seems as though water is coming from the left side….the water appears clear and not soapy or dirty….but there was a slight grit film in and on the left tray….
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This can be caused by low water pressure. The water inlet value will leak if there is not enough pressure to keep the valves closed. It can also be caused by a failing water inlet valve.
这个答案有帮助吗?
得分 1
3条评论:
Ok I will check the inlet valves ... I know water pressure is fine in the house... thank you.
完成的
i turned the cold water supply off and it stopped dripping...so does that mean its the inlet valve???
完成的
@kpsluder Remove the hose from the back on your machine and clean the wire mesh screen of any debris. Once it is clear, if there is still still leaking, the most likely cause will be the water inlet valve.
完成的
添加一条评论
添加你的答案
Pamela Sluder 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 32
过去 30 天: 173
总计 5,357
