跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
How to remove a MacBook cover screw that is broken without any tools
I have a macbook pro 15 inch 2015, when I tried to remove the case I notice that the bottom two screws near the trackpad won’t turn. When I take in for a closer look the screw seems to have been stripped or broken to the point that Icant remove it with a pentalobe screwdriver. I’ve tried using superglue, rubberband and even latex gloves, but it won’t work. I am planning to replace my battery. Should I use a drill to drill the screw and replace it with a brand new screw?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
you might try taking a drill bit with your hands to see if it will grab the screw enough to loosen it.
这个答案有帮助吗?
得分 2
1条评论:
I will try it thanks for the advice
完成的
添加一条评论
添加你的答案
Anthony Wijaya 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 73
