跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Boot looping after upgrade
I recently installed an m.2 SSD on my late 2013 27” iMac. Before reinstalling the screen with adhesive, it booted to MacOS like normal and showed the new SSD. I shut it down, disconnected the screen, installed new adhesive and reinstalled the screen.
Now when I try to boot it up the screen does nothing and it just plays the startup chime over and over again. I’m not sure if it could be caused by an issue with the screen installation or if I have a bigger issue.
I’m at my wits end, so hopefully someone has some advice; I’ll take almost any idea at this point, so thank you in advance for your thoughts!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What happens when you try booting up on an external bootable drive? Use the Option (⌥) key to enter into the Startup Manager so you can select the external drive.
Reference: Mac startup key combinations
I fear your M.2 and adapter solution is just not able to work in your system. I really don’t recommend them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steven Boughton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 43
