跳转到主内容
Device repair and information for HP's line of Pavilion 15" laptop computers.
Rumbling fan in hp laptop.
Hello everyone, I have a HP Pavilion Power 15-ec0006na 15.6 Inch Full HD Gaming Laptop. One of my fans has recently started rumbling, and I was just wandering if I have to disconnect the battery before I disconnect the fan. If so how would I do that. Thanks for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Definitely, Anything that haz power supply you Always want too Disconnect Battery incase you touch something that has current u won't short the whole thing!! And the rumbling is where the motor is mounted is loose or blade/ bearing in motor is bad causing motor too vibrate,,/ Rumble… Good Luck?? Danny mechanic
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Yes. Always, always disconnect the battery first after opening any laptop.
This video may help:
https://www.youtube.com/watch?v=B4xAzVaz...
这个答案有帮助吗?
得分 1
添加一条评论
Hi @astonseb5 ,
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.41 to view the necessary pre-requisite steps and then the procedure to remove/replace the fans.
As @aactech stated, always disconnect the battery as soon as possible when working inside a laptop and reconnect it as late as possible during re-assembly to help minimize any potential electrical problems when working in a laptop. You don’t have to remove the battery, merely disconnect it from the motherboard (see p.37)
There is always power present on the motherboard even when the laptop is switched off. The Power On/Off switch is not a power isolating switch. It merely signals the intentions of the user to the BIOS/OS as to what is wanted. Think of the laptop as being in an extremely low power state when off and not totally isolated from the power supply i.e. battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matthew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 382
