跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Screen problem in MacBook 2015 retina (vertical lines)
Hi guys. These lines have a mind of there own. Flickers and fades. When plugged into an external monitor it’s fine.
Any idea how to fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your external doesn't encounter the issue that points to the internal display has a problem. Here’s the guide to replace it 2015年中视网膜屏macbook pro显示器组件更换
Finding a good display will be hard as people who own these systems are not turning them in as they are still using them! I have two and you’ll need to kill me to get them as I’m very dependent on them. Still the best MacBook Pro Apple has produced even with its flaws and limitations.
这个答案有帮助吗?
得分 0
2条评论:
Geez! … Is there any compatible LCD panel without full assembly?
I can put it in without front glass if needed.
From my experience - using Windows based laptops - it’s always possible to buy compatible LCD panel to fit in with some modding, gluing or DIY.
完成的
@lex49 - This is the Apple world! Things are a bit different. There is no cover glass in this display. Here''s a teardown to give you an idea what's involved MacBook Pro Retina Display Teardown. You might be able to find a raw LCD panel but its a bit of work to fit it and get to work cleanly.
完成的
添加一条评论
添加你的答案
lex49 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 416
