跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad X1 Tablet (3rd Gen) 是一款 13 英寸笔记本电脑,可以像 Microsoft Surface Pro 一样在平板电脑、笔记本电脑和绘图模式之间切换。
Why doesn't my keyboard work?
Why doesn't my keyboard work? The computer slowly stop recognizing the keyboard. I suspect maybe a ribbon is wore-out from bending or a coin battery possibly died. When I connect nothing happens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I've had the X1 Tablet for 4 years. Replaced the battery twice, keyboard twice. Can only speculate that keyboard is too flimsy, an obvious weak link in an otherwise pretty well-designed product.
Buy a replacement keyboard soon on eBay: Lenovo no longer has them. Ditto for the battery. Worst case, use a Bluetooth keyboard & mouse.
由完成的
添加一条评论
2个答案
已选择的解决方案
Try reseating the connector. I had this issue earlier and it fixed it after a few tries.
这个答案有帮助吗?
得分 1
2条评论:
Can you tell me more about resetting the connector? Are you referring to the magnet? I tried cleaning the surface but that did not help. How do I reset the Connector? I am not sure what the connector is. Thanks so much for your help!!
由完成的
Unplug and replug it, and make sure the locking slide/clip is as tight as possible. I hope this helps.
由完成的
添加一条评论
I've had to replace both battery and keyboard twice: I'm on my third of each. The battery was always crap, never delivered quoted run time. I think the keyboard was similarly a weak point in an otherwise pretty solid unit.
Buy yourself a replacement keyboard (& battery too, while you're at it) on eBay: Lenovo is no longer carrying either part. Probably dumped their remaining service spares on eBay. You're bound to need them. The screen unit (contains all the electronics) is pretty robust and is serviceable. The keyboard is neither: if it's shot you cannot fix it.
Worst case, use an external portable Bluetooth keyboard + mouse.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Phillip Hawes 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 57
总计 4,902
