跳转到主内容
MacBook does not boot
Hi!
My Macbook Air 13” does not boot at all. The screen stays black and there is no sign of life at all. When I plug in the charger, it’s saying that it is charging (led goes orange) but the Macbook still won’t boot. Does anyone know what’s going on? I think it’s motherboard related, but before I order a new one, I want to be sure.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Replacing the motherboard fixed the issue. I want to thank everyone here!!
完成的
添加一条评论
3个答案
已选择的解决方案
It could possibly be your SMC chipset i have encountered this many times, especially in the Mac Minis and in certain macbook Air models
这个答案有帮助吗?
得分 1
4条评论:
Thanks for your answer! Is this an easy fix? Or am I better off to replace the motherboard?
完成的
better off replacing the whole machine in my opinion it honestly depends on the amount of time and money you would be willing to invest
完成的
Alright good to know, thanks :)!
完成的
Replacing the motherboard fixed it! Thanks!
完成的
添加一条评论
最有帮助的答案
Here are a few articles from Apple which may be helpful:
If your Mac doesn’t turn on
If your Mac doesn’t start up all the way
How to reset the SMC of your Mac
If you aren’t able to power on your system using these tips, you may have a faulty battery, charger, or DC-In board. To figure out the cause you’ll need to do some troubleshooting or take it in to a repair shop.
这个答案有帮助吗?
得分 2
8条评论:
Tested it with different chargers and this didn’t work. All the resets are tried but no sign of life. If the charger is in, it should boot no matter if the battery is faulty, right?
完成的
@dan0 some devices require a working battery to boot and I wouldn't put it past apple to do this as planned obsolescence
完成的
That's normally true. In some cases I've seen a bad battery cause power on issues that weren't resolved until a new good battery was installed, but I don't think that's what's going on here.
完成的
Alright. Well someone is bringing in a known working motherboard. I'll test and see what happens :)
完成的
If you have a faulty charging circuit and the input diode is faulty, it will stop your laptop from turning on as it detects a reverse current flow towards the charger from the battery. Try to remove the back cover and unplug the battery but nothing else and then plug in the charger and see if you can switch it on.
完成的
显示更多的3条评论
添加一条评论
Firstly, you may make some checks, such as indicator light, cable, power connection, display and so on.
Then, try running Disk Utility to fix Mac issues.
Or reset NVRAM/PRAM to have a try.
Following post can be useful to help you step by step:
https://www.minitool.com/data-recovery/f...
这个答案有帮助吗?
得分 0
1条评论:
Yes, the indicator light is on (orange). And can’t run disk utility as it won’t turn on at all.
完成的
添加一条评论
添加你的答案
koppie007 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 18
总计 485
