跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Microphone problem after screen replacement
Hello.
When I replace the display with a new LCD, then I screw the tape with (speaker-microphone-face id etc), while recording the front camera I hear a slight squeaking in the background. But when the tape is on the outside of the screen, it is all ok. Is it maybe some kind of lack of grounding in the screen? Is there any method to change it? (in the original display everything is fine) Any suggestions or help are welcome.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Yes, I checked everything. This little golden clip does not eliminate the problem. Flex is ok, everything works fine on the original screen.
完成的
添加一条评论
3个答案
Did you place back the little gold grounding clip as can be seen in step 22 of this guide? iPhone X 屏幕面板更换
Also double check the flex cables to ensure they are not damaged.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
I have 350 of the same replacement displays, I checked 30+ lcd's and they all have the same problem. (little noise - “piiiiii” when i recording front camera)
这个答案有帮助吗?
得分 0
添加一条评论
This is an issue with bad quality replacement frames. Sometimes it is easier to use a good quality screen to save the hassle.
这个答案有帮助吗?
得分 0
2条评论:
So you are saying that in my replacement displays, weak aluminum or other metal was used during production, which interferes incorrectly with the phone casing?
完成的
Yes exactly.
完成的
添加一条评论
添加你的答案
Lucas Szeyk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 388
