跳转到主内容
加入维修社区 - 创建账户
10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
I submerged my tablet in water how to repair
I dropped my tablet in the tub. I did the rice thing and it still will not charge or show anything on the screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you I will post my results
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @sexydrummerman
The water causes corrosion and provides circuit paths for the electricity which were not in the tablet’s operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Rice does not fix the problem Rice is for dinner, not repair
First do not try to charge or to turn on your tablet and then remove the battery as soon as possible from the tablet to minimize any further damage.
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible, do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there also. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the tablet might possibly work correctly again.
Here is a link to the ifixit Samsung Galaxy Tab 10.1 guides for repairing your tablet that may help.
If this process seems too daunting, take your tablet to a reputable, professional mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ben ford 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 83
总计 6,856
