跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Changing just earpiece speaker
Is it possible to just change the war phone speaker itself? Face ID and everything works but the earpiece speaker when on a call works but is very tinny. Is it possible? I don’t have an X at hand to strip and check the part.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, it can be done but it requires some soldering skills. If the volume is very low, then most likely the filter is all clogged up, the black mesh between the speaker and your ear. Open the phone, disassemble the proximity sensor flex (3 screws), and clean the filter with an old toothbrush and some isopropilic alcohol.
The best way to know if it is clean is holding it up against some light.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 74
