跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
Won’t startup fully (I need help)
The iMac, with no modifications, heats up and takes over an hour to boot. When it does boot it dosen’t work.
Internet recovery won’t work. It loads then it says an error ocrred and then it restarts
please comment if you need more info.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Reload your system from the original system installation DVD.
Pre-Installed MacOS:X 10.6.1 (10A2155)Maximum MacOS:X 10.13.x*
这个答案有帮助吗?
得分 3
3条评论:
The disk will go in for a second then pop out
完成的
Put the disk in partially. Hit the power on button and immediacy push it all the way in and hold down the c key.
完成的
I fixed it. Turns out the drive was messed up so I just changed it for a better one
完成的
添加一条评论
添加你的答案
Tsar_ Bomba 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 85
