跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Why isn't my touchscreen responding after digitizer repair.
LS,
My iPhone 3G stopped responding to my touch. Looking on this website i figured i had to install a new digitizer. So i replaced it using the front panel kit.
After i fixed this problem it still doesn't work. I think this problem could be a software problem, but i wouldn't know how to fix it.
Do you have any ideas?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What makes you think the fault is software related?
Did you notice the issue after an update / jailbreak attempt?
Firstly, try resetting / restoring to see if that works.
If not, then I would say disassemble and check your connections, especially cable 2 at the top end of the phone.
Did you definitely buy the right version of touch and fully secured it?
Sounds stupid but you wouldnt believe how many I repair with the wrong touchscreens on or the cable only half way home.
Hope I helped.
这个答案有帮助吗?
得分 2
2条评论:
+absolutely agree!
完成的
Well, i think it's a software problem because with my old digitizer it worked after it was 'broken' for a while.
I already tried the restoring/resetting, but it doesn't work as well.
I also bought the right hardware to fix my iPhone with, so that couldn't be the problem as well.
The only thing i could do is check the connections, but i don't know if that's going to help.
Thanks for the questions!
完成的
添加一条评论
添加你的答案
lesterverhoef1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,118
