跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Screen flickering when opened more than 45 degrees. Backlight works.
I recently started using my Macbook with an additional external screen. After a few weeks with this setup, connecting and disconnecting the external screen in between, the screen started flickering after I disconnected the external screen.
The flickering only occurs when the screen is opened more than roughly 45 degrees and sometimes stops when fully tilted back. The issue is not the backlight! The screen itself just turns black for a few fractions of a second, turns back on for a few moments up to several seconds and then the whole things starts over again. Most peculiar is that it stops at any angle as soon as I have the external screen connected.
An SMC and PRAM reset didn’t solve the problem. Booting in safe mode however does, but it happens again after leaving safe mode.
Theoretically my Macbook qualifies for the “flexgate” repair, but an Apple employee told me on the phone they will only fix it if the backlight is faulty, which is not the case for me.
Any input on how to fix this? This is so annoying, I can’t use the macbook without the external screen anymore. On the other hand I am quite happy with the macbook and would hate having to buy a new one, just because of this problem, as everything else on this machine is as good as new (after having the battery and top-case replaced for free not too long ago).
Thank you!
Update (02/06/2021)
I attached Videos of my problem. Some of you might ask now how I know the backlight is working, as the flickering is so short. Well sometimes it is longer, for example when I‘m scrolling through a document. Then you can notice that the screen is actually still lit and „just“ turned black.
Update (02/07/2021)
Here are the screenshots.
1. External screen connected
2. External screen disconnected
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I'm not sure I follow what you are encountering. Can you post a set of short vids so we can see how your system is reacting one with no external display and a second with the external connected from a closed screen to open, so we can see the displays reactions 在已经存在的问题里加入图片
完成的
I edited the original posting and added two short videos. Thanks a lot!
完成的
添加一条评论
4个答案
OK I get it! This looks like a power issue with the backlight logic. I’m wondering if the battery is causing this. Your display is likely offering power to your system so while its plugged in the power from the display is solving the problem. When you disconnect it the loss of power makes the system unstable.
So… Lets see what CoconutBattery tells us take a snapshot of the apps main window and post it here for us to see. Do one with the display connected and a second when it is disconnected you’ll want to give it a bit of time between the to states so we get a clean capture.
Update (02/07/2021)
The flex cable issue makes sense! But, why does plugging in the external display stabilizes it?
If it was the flex then plugging in or out of the external wouldn't change the internal displays reaction.
So what is different between the external being plugged in? Thats power! The USB plug carries power from the display to your system to charge it. When you've disconnected the external power connection your system is on battery. Which is why we started there.
While I was expecting the original battery, as you have replaced it you pull that off the list. That only leaves the charging logic within the main logic board.
Let's see if Activity Monitor catches something, Open it up and monitor the Energy tab. I don't think it will as its not very fast. A power meter might be able to see the power disruption like a MakerHawk USB-C Power Meter (6 digit resolution!) This is the most sensitive unit I have found.
In the end you’ll need to find someone with the deeper skills to diagnose what SMD or chip on your logic board needs replacement or replace the logic board.
这个答案有帮助吗?
得分 0
5条评论:
I added the requested screenshots above. Personally, I don't think it is the battery itself. I had it replaced when the flickering issue already started, and it didn't change after the replacement. Also, why would it be dependent on the angle of the screen if the battery was an issue? Wouldn't that indicate a mechanical issue, for example the known to be faulty display cable (i.e. the flexgate issue)?
完成的
The activity monitor didn't reveal anything suspicious. I will bring my computer to an independent repair shop who has done good work on my previous laptop. If something on the logic board needs to be replaced, I have to go there anyways. That way I can save the money for the USB-C Power meter. Thanks a lot for your dedicated help on this matter. I will update the thread after I have an answer from the repair shop. Until then - just out of curiosity - can you explain to me how the power issue can be related to the tilting of the screen?
完成的
Your display has a light detection system which measures both the background lights color and intensity. It's possible its the true failure but its not the cable its the circuit within the logic board thats failing to measure the lights value.
完成的
Just FYI for people with a similar issue: Before I had the time to bring my Macbook into the above mentioned repair shop, the flickering suddenly stopped over night. It's been fine for a week now. Hope it keeps being fine. I will post an update if it starts again.
完成的
Dear Mattes, is your MacBook still fine ? I just encountered this issue. Hope I don't have to replace the screen!!
完成的
添加一条评论
Mattes- Is your Macbook Pro still operating correctly? My screen just started doing this yesterday, also right after beginning to use an external monitor with it at work, and I haven't found a solution for when I'm using the Macbook Pro when not connected to an external monitor. Any tips or ideas for anything that may have helped to solve your issue?
Thanks!
这个答案有帮助吗?
得分 0
1条评论:
No, the problem returned a few weeks later. I wanted to have it repaired for months but I haven’t gotten around to it. I‘ve been using the MacBook with the external screen since the problem returned.
完成的
添加一条评论
Same prob as my daughter....
I've not checked this but this may help. Sounds interesting anyway - particularly the bit under the 'answer' about confusion between splitting the video signal. Please post success or otherwise...
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem, I change the screen and the motherboard and always the same problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mattes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 30
总计 1,271
