跳转到主内容
Guides and repair information for the Lenovo Thinkpad T430, a 14-inch business laptop by Lenovo.
25 个问题 查看全部
Why is my second hdd not working?
i have linux and widows both on my notebook in dual boot.
when i boot linux it works fine with the hdd mounted. but when i boot windows it is stuck on the loading forever. when i launch windows without the hdd it works. i managed to get the hdd work but windows was much slower. when i try to format the hdd on linux i get input/output error. but when i connect the hdd trough usb everything works. is it a hardware problem? how can i repair this ?
edit: windows 10 pro and linux mint 20
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Many variables here, firstly does your linux distro boot without the second hdd? When you are able to boot windows, do you do it from grub?
完成的
Hi @coconus ,
Is the latest BIOS version 2.82 installed?
完成的
i am not sure. how can i check version of the BIOS ?
完成的
Hi @coconus
When the laptop is first started and the Lenovo logo is on the screen press F1 to enter the BIOS setup menus. All the info should be there.
完成的
BIOS version is 2.82
完成的
添加一条评论
2个答案
已选择的解决方案
Hi @coconus ,
With the 2nd HDD connected, check that the 2nd HDD is not listed in the BIOS > Boot, boot priority list anywhere as it is a storage drive and shouldn’t be listed there.
If it is remove it from the list and then check if Windows works OK.
这个答案有帮助吗?
得分 0
1条评论:
it looks like it works. the windows runs fine now but i still get I/O error on linux(input output error). i will try to run the HDD on USB for some time to see if it wil work.
完成的
添加一条评论
The OS using the HDD will absolutely be slower because USB is currently slower than SATA, M.2, NVMe, or any other current hard drive technology. Also, HDD drives are slower than SSD drives.
SSD drive may speed up your system and eliminate the I/O errors.
这个答案有帮助吗?
得分 0
1条评论:
i have both OS on 120GB SSD split to two 60GB partitions in first slot for HDD
the HDD is 2TB and i want to use it as a drive for documents, videos...
the 2TB HDD is connected through the second slot for HDD the one where can be cd reader.
完成的
添加一条评论
添加你的答案
adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 621
