跳转到主内容
This device is a personal paper shredder manufactured by Fellowes, Inc. in 2005. The shredder has the capability of shredding 7 sheets of paper at once as well as credit cards, identification cards, and cards likewise of the same thickness.
What are the gear part numbers?
The primary and secondary gear teeth are stripped, do you have any idea what the part numbers are? I’ve looked everywhere I can think of. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I had a look around and couldn’t find any part numbers for the gears. The best thing you can do is count the teeth, measure the diameter and thickness and check if you can find a similar gear is a specialty shop that sells gears. Do note there are different type of teeth, so also pay attention to the form of those.
这个答案有帮助吗?
得分 1
4条评论:
What are the "tenths" that you're referring to?
I've only counted teeth so far (12/50). Once i get the dimensions, do you know of any sites that are set up to search by dimensions?
Thanks!
完成的
Oops, I meant teeth there. I've seen this website passing by in some other forums https://www.hpcgears.com/ but I think if you know the diameter & amount of teeth you could do a google search with that and get some results to sites that have advanced filtering.
完成的
Hi, I've helped others reproduce damaged plastic gears that you can't buy anywhere. Please message me and I'll be happy to help you. https://www.ebay.com/usr/krunkz
完成的
@mrmaster8300 self promotion on here is consider SPAM. Please feel free to add your services to your About page but not in Answers. You can refer from Answers to your About page but not to any outside link that will promote your business. On the about page it is okay to give more details about what it is that you do and your specialty, NEVER IN ANSWERS! and NEVER ON THE GUIDES
完成的
添加一条评论
添加你的答案
caleb.peacock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 368
