跳转到主内容
Can a broken tray that holds the color cartage be repaired?
My friend tried to stuff a black cartage into the color cartage slot and when we took it out a piece broke off. Now it won’t hold a new color cartage. Can the tray and brackets that hold the cartage be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
HI,
What is the make and the model number of the printer?
完成的
添加一条评论
3个答案
最有帮助的答案
Yes, but the issue with printers tends to be parts cost vs. whole brand new unit replacement totals out the machine with printers. In addition to that with these HPs unless you can somehow remove the printhead/cartridge carrier from the track belt, encoder strip and support bars without damage you need to change out the entire mech which usually means you need a donor.
Make your friend replace the printer if you really feel like you need to be “made whole” or can’t buy one yourself, or it gets you closure. Even if you just replaced the mech, you still have original waste ink pads and the rest of it is still original. Consumer grade printers are built to be easily recycled on a disassembly line, not repaired. If that was my mistake I’d just buy you a new one from Walmart for $50 and Office Space the one that was broken.
这个答案有帮助吗?
得分 2
添加一条评论
Yes, It is possible. And if you have any issue with the cartridges, you can find more details here.
这个答案有帮助吗?
得分 1
添加一条评论
I never personally try this.. but as far I know color and black cartage are different mixing this together might not result well..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dburbanklokey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 50
