跳转到主内容
型号A1318,闪存容量:32及64GB
299 个问题 查看全部
need to know how to make the touch screen work again
Hi I bought ipod on ebay and it connects to itunes but the touch doesnt work. It had been water damaged. I got a new digitizer and nothing. got the 91% isopropyl alcohol and cleaned it all and still nothing.
After I put it back together it still syncs,so thats good
Lcd does turn on
Could it be the digititer or the logic board??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
you might be unlucky and have a bad digitiser...check the returns policy, check you've ordered the right generation digitiser etc. Try again.
这个答案有帮助吗?
得分 3
添加一条评论
The part where the digitizer connects to could be bad. You would need to replace the motherboard flex cable. It's very difficult. You need the part and conductive tape... Heat gun and solder iron. I'd recommend staying away from iPods that work with the exception of touch response - many people think they repair as easy as iPhones, but in my opinion are much harder and less likely to survive liquid damage.
这个答案有帮助吗?
得分 2
添加一条评论
Double check the ribbon cable and the connection points.
这个答案有帮助吗?
得分 1
1条评论:
ok i'll see if they can change it.
完成的
添加一条评论
On the underside of the main board, there is a large, shiny heat shield protecting important components. Use a metal spudger to remove that piece, and scrub well underneath it. I have encountered water damage issues involving the components under that in the past. Its worth a try!
这个答案有帮助吗?
得分 1
2条评论:
cool ill try it
完成的
where the speaker is right?
完成的
添加一条评论
添加你的答案
david ortega 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,806
