跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
Ripped of contact on print board
Hi,
While changing SSD drive I ripped of one of the small connectors just above the battery, what is the best way of repairing the issue. I already got the advise of finding someone to soldering , but this will be unlikely the small contactor is embedded in a plastic body.
I thought trying to keep connector on its contacts with the help of black electrical tape. When dismounting the parts at the opening there is such tape strip on top which covers whole the connection area.
Added link to the pictures.
Thank you for your suggestions.
Regards,
Marc
Update (01/21/2021)
Hi Dan,
Thank you for your reply, I hope the pictures are clear enough about the issue.
It is the contact marked J123V next to TP 6 on the first picture, the second picture is the part which broke off.
Regards,
Marc
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Need to see what you've got here to help you 在已经存在的问题里加入图片
完成的
添加一条评论
2个答案
已选择的解决方案
The connector you broken off is the battery board data cable connector on the battery unit.
The easiest fix is just replacing the battery MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery following this guide 2017年款带功能键 的13寸 MacBook Pro 电池更换
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery图片
产品
$129.99
这个答案有帮助吗?
得分 1
2条评论:
Hi Dan,
Thank you so much for your answer.
But the sad and stupid side of the story is that the battery proposed on this website is more than double than the Market price here in the UK.
The market price for the battery is around £60 were on this website it is about £128.99 and unfortunately this difference is too big for my budget , adds to it that my previous employer left the UK and I am looking for new challenge.
I don't know if you know the people running this website, but with such price difference even with the excellence of service provided, they must miss out on quit a lot of business opportunity.
Maybe not too bad to make them aware of this.
Anyhow, stay safe and healthy,
Regards,
Marc
完成的
@marcvlo Did you convert the US Dollars to Pounds? I get £110 Pounds! I haven't seen this battery go for lass than that!
完成的
添加一条评论
Hi Dan,
Thanks for the follow up.
I put you here a screenshot of the price quote for this battery on the system.
regards,
Marc
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 85
