跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone x random faults
Hi everyone,
I’m having some issues with an iPhone X. I bought it used with low battery health and a cracked screen, both of which I replaced with replace base components. Now it is repaired I’ve noticed a few issues with the phone and I have no clue what is causing them.
Occasionally, maybe every half hour the phone randomly decides to restart, even when on charge. The phone is also slow to react to the power button.
If anyone has any idea what could be causing this or what tests I could do to see what the potential issues may be I would be very grateful.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi, Rory Sanders.
As you say that your iPhone X randomly restarts and reacts slowly to the Power button, I guess that there is something wrong with your iPhone system. You can try to update your iOS firstly. If it doesn’t work, then turns to iTunes and restore your iPhone X with it. Restoring your iPhone will erase all your phone data and settings and turns you back an iPhone that needs to be set as new for use. Compared with iOS update, I think that iTunes restore would fix system issues more completely and thoroughly. Alternatively, you can use a professional iOS repair tool like iSunshare iOS Repair Genius to check and fix your iOS. These kinds of tools can repair different kinds of iOS glitches while not damaging your phone content most of the time.
For more details, you can see:
Update iOS
Restore iPhone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rory Sanders 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 82
