跳转到主内容
The ZTE ZFive G LTE is a smartphone manufactured by the ZTE company in 2018. Model number: Z557BL.
8 个问题 查看全部
I hard reset ZTE - Z557BL and it won't connect to my network, why not?
I did a hard reset to grandson’s ZTE - Z557BL Tracphone and still cannot connect to wifi. Our internet and wifi work. I reset both the modem and router. Signal is excellent . The phone shows other neighborhood networks, but not ours. All other devices in our home connected fine when I put in our network SSID and password......what now???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Simone  You are right thank you!
完成的
Good, glad it helped
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds more like a router configuration issue, is it working on 2.4 or 5 Ghz? You may need to tinker with operating mode, channel, or device specific restrictions to make it visible to the phone. I suggest you back up your current working settings first(from the router’s web interface), then check Can't connect to home wifi and see if it works for you
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Darla Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 628
