跳转到主内容
2014年12月发布的由三星为亚洲市场推出的安卓智能手机,已知有很多型号。
118 个问题 查看全部
Can't connect to home wifi
My home wifi works on my other mobile phone and laptop. And I've connected on other wifi with A5, but at home I've got nothing. Please help! Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi
Does your A5 detect your home WiFi network at all?
If it does, have you tried the "forget this network' option, shut down and restart the phone and then try to reconnect again? If so what happens?
If it doesn't is your home network working on 5GHZ or 2.4GHz?
If it is 5GHz what channel have you set in the router?
Try setting the 5GHz channel to either 36, 40, 44, or 48 and see if the A5 detects the WiFi network.
这个答案有帮助吗?
得分 5
11条评论:
I've just did a reset on my router and it worked. Thank you very much!
完成的
Thanks ! Changing the canal from "Auto" to 40 on my router did the trick and now the phone sees the network.
完成的
How do you change the routerchannel
完成的
Hi @dianeruth ,
What is the make and model number of your router? (Info is usually found on a sticker on either the back or under the device)
完成的
DSL-3680 Broadband Wireless N150 ADSL2+Router
完成的
显示更多的6条评论
添加一条评论
Hello there,
Try these and see if you can fix the problem
1. Try forget network and restarting your phone
2. Change the WiFi Password and restart device and then check
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 13,968
